Displays the incident counters for events.
event condition | Specifies the event condition to display. |
all | Specifies that all events are to be displayed. |
event component | Specifies that all the events associated with a particular component or subcomponent should be displayed. |
include | Specifies if one or more targets should be included in this event. |
notified | Specifies the number of times this event has occurred. |
occurred | Specifies the number of times this event has occurred since the last clear or reboot. |
severity | Specifies the minimum severity level of events to display (if the keyword only is omitted). |
only | Specifies that only events of the specified severity level are to be displayed. |
If severity is not specified, then events of all severity are displayed.
This command displays the incident counters for each event specified. Two incident counters are displayed. One counter displays the number of times an event has occurred, and the other displays the number of times that notification for the event was made to the system (an incident record was injected into the system for further processing). Both incident counters reflect totals accumulated since reboot or since the counters were cleared using the clear log counters or clear counters command, regardless of whether it was filtered or not.
The keywords include, notified, and occurred only display events with non-zero counter values for the corresponding counter.
This command also displays a reference count (the column titled Rf in the output). The reference count is the number of enabled targets receiving notifications of this event.
See the command show log for more information about severity levels.
To get a listing of the event conditions in the system, use the following command:
show log eventsTo get a listing of the components present in the system, use the following command:
show log componentsThe following example displays the event counters for event conditions of severity debug-summary or greater in the component STP:
# show log counters stp included severity debug-summary Component SubComponent Condition Severity Occurred I Ntfd Last Notified Time ----------- ------------ ----------------------- ------------- -------- - ---- ---------------------- STP AllocClntMsgFail Warning 0 Y 0 STP BindAutobindFail Error 0 Y 0 STP ChangeTag Warning 0 Y 0 STP CreatDmnFail Warning 0 Y 0 STP DomainDisable Warning 0 Y 0 STP DomainEnable Warning 1 Y 1 01/05/2001 23:43:39.03 STP DsblPortBrdgDtect Warning 0 Y 0 STP DsblPortLoopDtect Warning 0 Y 0 STP EnblPortTimerExp Warning 0 Y 0 STP ESRPConflict Error 0 Y 0 STP GetAvailDomainFail Error 0 Y 0 STP GetAvailPortFail Error 0 Y 0 STP LicenseError Warning 0 Y 0 STP NULLBridgeId Error 0 Y 0 STP PhysPortAssocInv Warning 0 Y 0 STP PhysPortInv Error 0 Y 0 STP PortAlrdyBndDmn Warning 0 Y 0 STP PortInuse Error 0 Y 0 STP PortModeNotExpct Error 0 Y 0 STP SendClntMsgFail Warning 0 Y 0 STP UnsupPhysInterface Critical 0 Y 0
The following example displays the event counters for the event condition PDUDrop in the component STP.InBPDU:
# show log counters "STP.InBPDU.Drop" Component SubComponent Condition Severity Occurred I Ntfd Last Notified Time ----------- ------------ ----------------------- ------------- -------- - ---- ---------------------- STP InBPDU Drop Error 0 Y 0 Occurred : # of times this event has occurred since last clear or reboot Flags : (*) Not all applications responded in time with their counters I(ncluded): Set to Y(es) if one or more targets filter includes this event Notified : # of times this event has occurred when 'Included' was Y(es)
# show log counters aaa Component SubComponent Condition Severity Occurred I Ntfd Last Notified Time ----------- ------------ ----------------------- ------------- -------- - ---- ---------------------- AAA accountLockedOut Warning 0 Y 0 AAA accountMod Info 0 Y 0 AAA authFail Warning 0 Y 0 AAA authPass Info 2 Y 2 02/27/2018 16:27:10.80 AAA changePass Info 0 Y 0 AAA ChgAccntPrvlgFail Notice 0 Y 0 AAA ChgAccntPrvlgOK Notice 0 Y 0 AAA ClearSessAccntDel Notice 0 Y 0 AAA ClearSessAccntPrvlgChg Notice 0 Y 0 AAA createAccount Info 0 Y 0 AAA CreateEncryptAccnt Info 0 Y 0 AAA DecryptMaxStrSizExcd Warning 0 Y 0 AAA deleteAccount Info 0 Y 0 AAA EnblFIPSModeFail Error 0 Y 0 AAA EnblFIPSModeOK Notice 0 Y 0 AAA InitRAccSvVr Warning 0 Y 0 AAA InitRAutSvVr Warning 0 Y 0 AAA InitVlanLibFail Error 0 Y 0 AAA ipv6ForceLocal Debug-Summary 0 N 0 AAA localAuthen Debug-Summary 2 N 0 AAA logout Info 2 Y 2 02/27/2018 16:06:58.31
Last notified information was added in ExtremeXOS 22.5.
